    Новый логотип JOOYFACT Store
    Тема по ним тут:
    Процессор: NOVATEK 96658
    Матрица: SONY IMX 322
    Язык: английский, китайский
    Фото:
    Как отличить - фото
    Прошивка от Питера
    #1 Biker81, 19 сен 2016
  2. Hi guys from Greece,i found usefull information to your site.
    Yesterday i install the dvr,is with imx 323 sensor and firmware CARDV_IMX322/3_2059_20161013V1059.
    Parking mode is contrled by gsensor,if dvr is off and parking mode on when you knock front glass starts recording for one minute.I believe if gsensor set to high then you must knock hard to awake.
    Motion sensor is working if dvr is on and not recording,my wifi is always on and when not phone is connected,i have to turn it off manually.
    I thought that i'll have redio interference because the antenna front but there is no,i'll check the next days.
    I have bought that cpl filter and have cut the back frame so i can stick it close to the lens.The frame can seen only a little at up left corner(i don't know why only to that spot was visible) https://www.aliexpress.com/item/Sup...32581635844.html?spm=2114.13010608.0.0.j4afUe
    I use lercenker programm
    Video sample
    Screenshot_20170112-174858.png Screenshot_20170112-192111.png 2017_0114_130814_001.JPG
      1,3 МБ
      1,1 МБ
      1,1 МБ
    #241 pitbull, 15 янв 2017
  3. Ну, значит модель проапгрейдили. Я купил в конце декабря. У меня молчит и пикать ему там нечем. Хотя, я сам бы не против был бы, если бы он пикал что начал писать. Светодиоды нефига не информотивно мигают. Они всё время в режиме WI-FI у меня, то есть синим мигают
  4. Good day.
    Today I found the receptionist. Firmware version is the same as you.
    With the features of each function is not yet understood. In this Your information is useful.
    I then did not understand how to turn off Wi-FI. A short press on the power button only forces the disconnect device, but does not disable the Wi-FI. I constantly blinking blue LED. Or, often, when one is not connected, or rarely, if connect by Wi-FI.
    It is unclear if Gsensor off, shall operate parking monitoring mode?
    Again, it is not clear purpose motion detection mode, if the DVR forced himself begins recording after switching on. If motion recording begins only if the record had not conducted, it turns out, someone had to stop her.
    Well Gsensor levels of sensitivity, it is not clear, for example, Low mode, this low sensitivity, or is sensitive to weak shocks?
    ________________________________________
    Доброго дня.
    Я сегодня установил данный регистратор. Версия прошивки та же что и у Вас.
    С особенностями каждой из функций не разбирался пока что. По этому Ваша информация полезна.
    Я то же не понял как выключить Wi-FI. Короткое нажатие на кнопку включения всего лишь принудительно заставляет устройство отключиться, но не отключает Wi-FI. У меня постоянно моргает синий светодиод. Либо часто, когда никто не подключен, либо редко, если подключиться по Wi-FI.
    Непонятно, если Gsensor выключен, то будет ли работать режим мониторинга парковки?
    Опять же, не понятно назначение режима детектора движения, если регистратор принудительно начинает сам запись после включения. Если запись по детектору движения начинается только если запись до этого не велась, то получается, кто то её должен был остановить.
    Ну и уровни чувствительности Gsensor, не понятно, например режим Low, это низкая чувствительность, или это чувствительность к слабым толчкам?
  5. Может каму то пригадится данная информация.
    Сегодня перед тем как установить регистратор, замерил дома ток потребления.
    1,2mA - в выключенном режиме.
    140mA - после полного запуска, то есть примерно через 20 секунд.
    160mA - если подключиться к регистратору по WI-FI.
    123mA - Если подключиться через WI-FI и остановить запись. Примерно столько же, если после этого отключиться.
    Самый большой ток, который я смог стабильно зафиксировать, был около 180mA.
    То есть, если оставить во включенном состоянии то, я думаю за 1-2 дня разрядит акумулятор. То есть за выходные.:) То же самое и с выключенным состоянием, уедишь на отпуск, приедишь, а акумулятор разряжен..
    В режиме мониторинга парковки не измерял, так как пока не псовсем понял подробностей, как он работает и как в него попасть.
    Как отключить WI-FI так и не понял. Он всё равно почему то виден в доступных сетях, и если по этой сети нажать, то телефон к ней подключается. Пробовал коротким нажатием на кнопку питания, просто отрубает активные соединения. Подскажите, как его отключить?
  6. I have a rearview mirror with lcd monitor and connect dvr there.
    When the dvr is recording if you press power button twice the wifi stops,if you long press the dvr shut down.Check it while you have connect your phone to understand the operation.The blue led blinking means that the dvr is recording,if only red led blinking the dvr is on,not recording,no wifi connect.
    If you set gsensor off the parking mode doesnt operate,if you set it at low then means that the dvr can
    understand and the weak shocks.
    Motion detection me either don't know how works,i think when test it records for three minutes.Maybe the operation is if you have off the car and you press power button to the dvr to set it to stand by mode and writes clips if there is detection infront.
    Or if the parking mode is triggered(because in this mode writes only for one minute)if it's sense motion detection keeps writes longer clips
  7. @pulsar_85 спасибо за IP адресок, т.е. с ноутбука из под винды тоже можно связываться с регистратором?
  8. @pitbull спасибо за информацию о том как отключить wi-fi. У меня получилось отключить при помощи двойного нажатия.
  9. jooy-a1 ОТКЛЮЧЕНИЕ Wi-Fi
    При двойном нажатии кнопки Power в режиме записи происходит отключение Wi-Fi, при длительном нажатии/удержании кнопки - видеорегистратор выключается
    • Не Нравится Не Нравится x 1
    #248 LEONавто, 19 янв 2017
  10. Motion detection is uselles,can't record if the car is off.I couldn't make it to cooperate with gsensor and parking mode.
    I have set gsensor to medium,in parking mode if you knock front glass records for one minute.There is no random record at night.
    20161013V1059 is the last firmware,Peter(JOOY store) said to stay with that
  11. В общем, решил я отключить режим парковки (Perking Guard). Из-за него на светофорах или когда подолгу стоишь в пробках, регистратор думает, что я припарковался (в кадре мало движения) и прекращает писать видео. А с учетом того, что перед записью нового клипа после остановки он "думает" где-то секунд 5-10, паузы получаются значительными.
    #250 Alfsoft, 22 янв 2017
  12. I have not noticed something like this from parking mode.I thought that when is on(parking mode) it's starts writing when something hit the car.I'll try to replicate it,although i have noticed when the dvr is recording if i turn on or off wifi stops recording and starts again after 8-10 seconds.
  13. Кто сталкивался с проблемой перезаписи, не удаляет файлы при заполнении карты памяти далее не пишет.В настройках не нашел ничего.
  14. Всем привет! Купил я себе такой ВР и я заметил что сегодня пока грел авто решил посмотреть как пишеться, все норм дата 30.01.2017 ну норм и поехал, по пути на работу заехал в транспртную, а за тем на работу! день машина стояла не ездила, далее в 18 часов я поехал домой проверять ничего не стал, приехал домой, вытащил флеху посмотреть как пишет и вообще порядок видео на компе! Вставив флешку увидел разные даты. Сначала он записывал как и полагалось 30.01.2017 а потом несколько роликов 01.01.2014 , а потом снова 30.01.2017 и вечером есть тоже видео смешаное.
    Ниже прикреплю фотку там по времени справа видно в какое время как писалось видео! В чем может быть причина?
  15. #254 Uksus17, 30 янв 2017
  16. Спасибо за перевод. Будем пробовать. Перед установкой удалить английскую версию.
    --- Сообщения Объединены, 31 янв 2017 ---
    Возможно пропадает или низкое питание на + В, например при включении стартера. У меня такое было, закономерности пока не нашел.
  17. Lercenker/Регистратор v2.05 Русифицированная версия.
    Программа для управления видеорегистратором, просмотром, передачей файлов и т.п.
    Перед установкой программы:
    - удалить имеющуюся версию (т.к. приложение имеет другую подпись)
    - с карты памяти (или внутренней памяти) девайса удалить папку /DCIM/Lercenker, т.к. при копировании файлов на девайс будет создана новая папка /DCIM/Регистратор
    Скриншоты программы:
    [​IMG] [​IMG] [​IMG] [​IMG]
    Скачать программу: Регистратор v2.05
    #256 Uksus17, 31 янв 2017
  18. Поставил JOOY A1 _658 _imx3223_20161013V1. Особых изменений пока не обнаружил, за исключением несколько иной логики выключения Wi-Fi (сейчас двойное нажатие на вкл, раньше было одно). Поколупал бинарник прошивки на предмет SSID WiFi. Чего бы вы там не рисовали в файле config, имя сети будет состоять всё равно из не более 8-ми знаков. Тот кто писал, что ему удалось таким методом 10 вкорячить, просто льёт воду (зачем только, непонятно).
    Прошивать можно как с файлом config, так и без него. В последнем случае просто не изменится номер прошивки, отображаемый в приложении. Зато сохранятся все предыдущие настройки.
    В остальном, мне кажется, что из этого устройства больше ничего не выжать. Вполне себе добротный середнячок за небольшие деньги. Планирую заказать ещё один девайс на второе авто.
  19. uksus17, хочу сделать несколько замечаний по переводу: "стабилизатор изображения" - там было "WDR", WDR- wide dynamic range никак не связан со стабилизацией,
    "Стереть карту" желательно написать "форматировать", а то некоторых пользователей будет вводить в заблуждение пока не появиться следующее окно. А в общем отличный перевод.
  20. Исправил, перезалил :)
    #259 Uksus17, 5 фев 2017
  21. подскажите пожалуйста а на кратковременное пропадание асс регистратор как реагирует? есть какие то настройки или реле времени надо будет прикручивать?
