  2. Ну да, точно. На скрине 1920 детализация просто показалась получше..
    eneral
    Complete name : D:\1920х1080.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (mp41/avc1)
    File size : 86.4 MiB
    Duration : 22s 699ms
    Overall bit rate mode : Variable
    Overall bit rate : 31.9 Mbps
    Encoded date : UTC 2016-01-24 12:21:17
    Tagged date : UTC 2016-01-24 12:21:17
    Writing application : vlc 2.2.1 stream output
    Comment : QuickTime 6.0 or greater
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : [email protected]
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=8
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 22s 656ms
    Bit rate mode : Constant
    Bit rate : 32.0 Mbps
    Width : 1 920 pixels
    Height : 1 088 pixels
    Original height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.511
    Stream size : 86.2 MiB (100%)
    Language : English
    Color range : Full
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Source duration : 22s 684ms
    Bit rate mode : Variable
    Bit rate : 64.0 Kbps
    Maximum bit rate : 83.6 Kbps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 48.0 KHz
    Frame rate : 46.875 fps (1024 spf)
    Compression mode : Lossy
    Stream size : 177 KiB (0%)
    Source stream size : 177 KiB (0%)
    Language : English
    mdhd_Duration : 22699
    General
    Complete name : D:\2304х1296.mp4
    Format : MPEG-4
    File size : 121 MiB
    Duration : 28s 75ms
    Overall bit rate : 36.1 Mbps
    Encoded date : UTC 2016-01-24 12:17:10
    Tagged date : UTC 2016-01-24 12:17:10
    Video
    Format : AVC
    Format profile : Main@L5
    Codec ID : avc1
    Duration : 28s 61ms
    Bit rate : 36.0 Mbps
    Width : 2 304 pixels
    Height : 1 296 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.402
    Stream size : 121 MiB (100%)
    Language : English
    Color range : Full
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 28s 75ms
    Source duration : 28s 56ms
    Maximum bit rate : 69.4 Kbps
    Stream size : 219 KiB (0%)
    Source stream size : 219 KiB (0%)
    Language : English
    mdhd_Duration : 28075
  3. Да и видео это мне больше нравится. Катаюсь постоянно с разрешением 1920х1080х30, другие ставлю только для каких-либо сравнений.
  4. Да она на самом деле лучше. Не может же нам двоим казаться))
  5. Да. детализация в 1920х1080х30 лучше чем 2304х1296х30
  6. Сделал увеличение "стоп кадров", разницы практически нет. Не понятно то ли не хватает битрейта для SHD, то ли процессор не справляется с кодировкой. Но факт то что SHD пока ни какого преимущества не несет, увы.
  7. Доброй ночи!
    А у ВАС монитор SuperHD и соответствующее железо?
    • Не Согласен Не Согласен x 2
  8. Чтобы увидеть детализацию на стоп-кадре, не нужен ни супер монитор, ни железо.
  9. Доброй! Железо обычное. SuperHD монитор не требуется что бы увеличить картинку. Воспользовался фото редактором Gimp. Можно то же самое проделать и в paint.
  10. Добрый день всем!
    Есть вопрос по SpeedCam, точнее, по базам самих радаров. Складывается такое ощущение, что база с пробелами - не о всех камерах есть предупреждения или только в одном направлении. Город Орел. В базе с сайта http://speedcamonline.ru все радары в городе есть и, вроде как, актуальны. Так, собственно, сам вопрос - откуда берется сама база?
  11. Укажите типы радаров которые есть на спидкам и нету в базе. Возможно берётся база только стрелки и малошумки, в таком случае стационарных крисов и Арен в базе не будет, потому что они обычными детекторами хорошо ловятся.
  12. Это действительно так и это неоднократно было проверено. Сам давно остановился на этом режиме и больше не экспериментирую. Почему преимущество режима SuperHD не заметно? Теоретически ведь все «козыри» у SuperHD. В чем причина, не знаю. Только Калининград это мог бы объяснить. Самое лучшее по качеству видео сегодня обеспечивает прошивка ORANGE-4 в режиме FullHD 1920х1080 30p, качество - ОТЛИЧНОЕ, замер экспозиции – ТОЧКА.
    #4571 Туляк, 25 янв 2016
  13. Вот из http://speedcamonline.ru
    7375. Маломощный Адрес: 57-05-КРД Орел Скорость: 60 Курс: 198
    7376. Маломощный Адрес: 57-05-КРД/2 Орел Скорость: 60 Курс: 18
    регистратор молчит,радар работает точно. И мобильные засады в сторону Брянска как-то только в одном направлении, хотя там сидят почти всегда в обе стороны (район д. Звягинок).
  14. Подскажите кто знает как добавить камеры в базу speedcam, некоторых камер нет в базе нашего ВР. г. Волжский Волгоградская область.
  15. Добрый день!
    А кто с этим спорит?
    Это утверждать не корректно ,не имея на то технических возможностей! ИМХО.
  16. А 1080р 60 кадров как по сравнению 1080р 30 кадров? Для дневного времени суток.
  17. Особого преимущества 60 кадров в секунду в сравнении с 30 кадрами в секунду не заметил, разве только места на карте памяти ролики занимают больше. Кто-то на форуме писал, что 45 кадров в секунду обеспечивают более плавное видео в сравнении с 30 кадрами.
    #4576 Туляк, 25 янв 2016
  18. А какие технические возможности для этого нужны?! По моему это можно сделать даже на смартфоне. Практически любой видео плеер умеет сохранять стоп-кадр. Сохраняете две картинки, увеличиваете и сравниваете качество. Все просто. Что бы действительно увидеть разницу в качестве - наверно нужно ждать модели с 4К.
    #4577 diger.mpt, 25 янв 2016
  19. Нет!С базой действительно в последнем обновлении много недочётов.Крисов стационарных много,беда в том,что они обозначены просто как стационарный радар и голосит о них регистратор постоянно(а о некоторых молчит).Корректировать и фильтровать нет возможности,от этого спидкам в регистраторе стал раздражать.По прежнему ругается на Кордоны Кречетом,при том,что куратор базы у нас по Воронежу человек грамотный.
  20. Лучше вместо гонки мегапикселей и разрешений, матрицу покрупнее, а то с динамическим диапазоном пока грустно. В условиях пасмурного подмосковного январского дня уже примерно с 16 часов цифры на встречных номерах замыливаются шумом. И даже о FHD речь, к сожалению, не идет. Причем глаз еще не видит уменьшения света, относительно середины дня, а рег.вынужден увеличивать выдержку, попутно увеличивая шум.
  21. Не знаю, как другим, мне глубоко фиолетово к радару какого типа я приближаюсь, ведь в случае превышения установленной скорости штраф придёт независимо от модели радара. Главное, чтобы предупредил в случае превышеия скорости о приближении к радару и необходимости снизить скорость. К примеру на MapCamDroid все стацинарные камеры так и называются без разделения на типы и модели просто и логично и меньше путаницы.
    • Согласен Согласен x 7
