Street Guardian SG9665XS Спойлер: ТТХ Processor: Novatek NT96650 Lens: 7 Element all Glass lens, 120° horizontal viewing angle CMOS sensor: Aptina AR0330 Video resolution: Full HD 1080P at 30fps @ 15Mbit/sec Video format: H.264 compression, MOV format LCD display: 2.0-inch HD TFT screen Microphone: Built-in, on/off menu selectable Speaker: Built in Storage media: MicroSD card, 32GB Class10 recommended, 128GB maximum* Gapless recording: Supported Recording cycle: Menu selectable 1 min/3 min/5 min Date stamped video: Supported Motion detection: Supported Soft shutdown: Supported, last file save and soft shutdown Screen saver: Supported, menu selectable 10sec, 30sec, 60sec, off Built-in G-sensor: Yes, with adjustable sensitivity Incident file protect: Automatic by G-Sensor/Manual emergency by button Exposure compensation: Automatic White balance: Auto Language: English/Spanish/Russian/Portuguese/German/Italian/Japanese/French/Simplified Chinese/Traditional Chinese Power supply: Fail-safe Super Capacitor RTC: (Real Time Clock) Supported Direct 12v~24v input Unit Net Weight: 65g Unit size: 50 x 76 x 32mm ( with lens ) Спойлер: MediaInfo General Complete name : G:\DCIM\100MEDIA\2016_1014_192123_078.MOV Format : MPEG-4 Format profile : QuickTime Codec ID : qt 0000.00 (qt ) File size : 326 MiB Duration : 3 min Overall bit rate : 15.1 Mb/s Movie_More : CarDV-TURNKEY Encoded date : UTC 2016-10-14 19:24:22 Tagged date : UTC 2016-10-14 19:24:22 Origin : NVT-IM Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : [email protected] Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=15 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 3 min Bit rate : 13.9 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.224 Stream size : 300 MiB (92%) Language : English Encoded date : UTC 2016-10-14 19:24:22 Tagged date : UTC 2016-10-14 19:24:22 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 3 min Bit rate mode : Constant Bit rate : 512 kb/s Channel(s) : 1 channel Sampling rate : 32.0 kHz Bit depth : 16 bits Stream size : 11.0 MiB (3%) Language : English Encoded date : UTC 2016-10-14 19:24:22 Tagged date : UTC 2016-10-14 19:24:22 ориг. - https://yadi.sk/d/5U3b6TxewnxEK
