Explay DVR-013
Тема в разделе "Explay", создана пользователем Exios, 5 ноя 2013.
  1. Купил себе сегодня это чудо за 990 руб в Связном.
    Снимает без пропуска между отрезками
    MediaInfo:
    General / Container Stream #1
    Total Video Streams for this File.................1
    Total Audio Streams for this File.................1
    Audio Codecs Used.................................ADPCM
    File Format.......................................AVI
    Play Time.........................................5mn 0s
    Total File Size...................................463 MiB
    Total Stream BitRate..............................12.9 Mbps
    Video Stream #1
    Codec (FourCC)....................................MJPG
    Frame Width.......................................1 280 pixels
    Frame Height......................................720 pixels
    Frame Rate........................................30.000 fps
    Total Frames......................................9000
    Display Aspect Ratio..............................16:9
    Scan Type.........................................Progressive
    Color Space.......................................YUV
    QF (like Gordian Knot)............................0.616
    Video Stream Length...............................5mn 0s 0ms
    Video Stream BitRate..............................17.0 Mbps
    Bit Depth.........................................8 bits
    Video Stream Size.................................609 MiB
    Audio Stream #1
    Codec.............................................ADPCM
    Codec (FourCC)....................................11
    Audio Stream Length...............................5mn 0s 223ms
    Audio Stream BitRate..............................64.0 Kbps
    Audio Stream BitRate Mode.........................CBR
    Number of Audio Channels..........................1
    Sampling Rate.....................................16.0 KHz
    Bit Depth.........................................4 bits
    Audio Stream Size.................................2.32 MiB (1%)
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Ночная съемка
  3. Видео мое
  4. это ей реально повезло :)
  5. Никто не знает случаем, как его разобрать?
  6. http://www.drive2.ru/l/2552773/
  7. @Exios
    Спасибо.
    В данной теме мега полезная ссылка и опыт.
    Я подозревал, что если он вскрывается то должен именно с этой стороны. Но уж очень хорошо крышечка приклеена и это заставило сомневаться и попробовать ковырять его в других местах. Эх, дурная голова, нет чтоб сразу у знающих людей спросить или правильно сформулировать вопрос Гуглу, ведь очевидно, что в первую очередь его разбирают по причине диодов. Будем вскрывать уверенней. :)
    Вскрыл. Светодиоды выпаивать не стал чтобы потом отверстия не заделывать, просто порезал им по одной ноге. Аккуратно подцепить крышку на моем экземпляре никак не получалось, уж очень она плотно и заподлицо вклеена. В итоге зацепил тонкой отверткой за отверстия в крышке, слегка отогнув их и с усилием потянув отклеил, перед отклеиванием немного погрел крышку феном жены для размягчения клейкого слоя. :)
    Теперь висит в кошке, назад снимает.
    #7 unreal, 4 сен 2014
  8. Добавлю немного про этот не побоюсь этого слова Мегадевайс. :)
    Была нужна камера для съемки назад, но недорогая по причине большого вопроса использования ее в Кашкае, так как стекло задней двери тонировано, подзапилено и кроме того в Кашкае оно почти всегда грязное, как минимум в пыли :( .
    ВР был куплен новым в Связном за 600 с небольшим рублей, и с учетом истраченных бонусов обошелся почти даром. :) :) :)
    И самое главное, я доволен покупкой :). Я был готов к тому что ВР разочарует, но он снимает :) , и нельзя сказать что очень плохо. Во всяком случае он в полной мере оправдал потраченное на него.
    Даже за такую цену недостатки у него есть, это автоматически подключаемые при низкой освещенности светодиоды, но этот недостаток очень легко лечится их удалением, либо (что на мой взгляд правильнее т.к. не портит внешний вид) отключением от них питания перерезанием ножек. Самое сложное здесь вскрытие рега, но это только если нет подсказки (за подсказку спасибо @Exios). Второй недостаток это размещение слота карты памяти внутри площадки на которую крепится кронштейн. Для извлечения карты приходится снимать рег. Но это не критичный недостаток.
    В моем случае отвратительный звук (выключил, т.к. сзади он мне не нужен).
    Плюсы -
    Цена.
    Вполне неплохо снимает за свою стоимость.
    ВР на вид очень качественно выглядит и неплохо собран, миниатюрен.
    Достаточно длинный шнур питания в комплекте (правда мне назад все рано не хватило, не критично, будет время подключу к проводке в двери).
    На всторенном аккуме он у меня снимал автономно на парковке около двух часов (не люблю аккумы, но раз уж он есть...).
    Вполне себе для него неплохой поворотный кронштейн на скоче (скотчей целых 3 штуки в комплекте).
    По ттх выше все в общем сказано. MJPEG, HD, 30fps. Добавлю по битрейту и алгоритму съемки. Битрейт не постоянен, днем бывает и 24 мбс, так что размер роликов не маленький, минута бывает 158 Мб. У ВР есть ночной режим, который как я понял включается при низкой освещенности (регулировка недоступна), при этом включаются светодиоды (вылечено :)) и снижается битрейт до 4-6 мбс (ночью высокий битрейт не так актуален как днем).
    Примеры видео (по 1 мин.) -
    день
    https://yadi.sk/i/lD5Cm-S6bb8Pu
    ночь город
    https://yadi.sk/i/zuXW0Crqbb8Qp
    ночь трасса
    https://yadi.sk/i/tF-V_zNobb8Ru
    Возможно передвину ВР поближе к стеклу, закрепив его на стекле, сейчас он закреплен на обшивке двери и будет время возможно поиграюсь с настройкой фокуса.
    Пока не глючит, стабильно пишет, роликов не теряет...
  9. За свою цену вполне норм ВР, вот только бы жрал памяти поменьше вообще было бы отлично
